gas pedal feels stiff
  • Thread starter Thread starter armin92284
  • Start date Start date Nov 23, 2004
A
armin92284
24
  • Nov 23, 2004
My gas pedal feels stiff on my stang. How do i adjust it so it isnt so hard to push?
The Shape
2,224
East ARKANSAS Delta
Nov 23, 2004
  • Nov 23, 2004
Mine is the same way. I am not sure what you can do about it though. You get used to it pretty quick the problem is when you drive something else. Like for instace I am so used to my car that when I drove my neighbors Durango the other night I accidentaly spun the tires at the first two stop lights before I got used to the soft pedal it has.
HISSIN50
34
129
Nov 23, 2004
  • Nov 23, 2004
i might check the cable for frayed spots on the cable and proper alignment of the cable. i dont know how stiff it is (i'm not there with you)- as TS noted, stang pedals can be stiffer than others (i like it - easier to modulate while heel/toeing).
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Nov 23, 2004
  • Nov 23, 2004
I agree. I would check for binding along the cable -- maybe look for something suck in the TB linkage, even check the carpet under the pedal (floor mat?). Probably not a good thing to either have it eventually stick or not work at all, so worth looking into...
F
Flyin88LX
28
Colchester IL
Nov 24, 2004
  • Nov 24, 2004
Mine feels pretty good so I would check for binds or something frayed
87gtconv
ragtopman
2,595
Southern Calif
Nov 24, 2004
  • Nov 24, 2004
Last time mine was really stiff and eventually it actually hung up. The fix was to adjust the idle speed screw. I had it so far off that it started to bind up in the TB.
A
armin92284
24
  • Nov 24, 2004
where is the idle speed screw located? Sorry, im still a noob
NYC LSC
626
Staten Island, NYC
Nov 24, 2004
  • Nov 24, 2004
Right behind where the throttle cable attaches to the throttle body. It faces towards the front of the motor, on the backside of the TB.
R
Rock777
195
Troy, IL
Nov 24, 2004
  • Nov 24, 2004
Mine freed up a ton after cleaning the throttle body out real good.
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Clark302
C
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
