Ok, so lately I've been getting pissed off that my stang has no power and seems to be dogging alot.
So, last night I decided to do something about it. I did the usual routing stuff..
Plugs.. Look good
Air Filter.. Yup.. It's ok.
Just for $hits and giggles I took off the air inlet tube from the filter to the throttle body and started playing around with the throttle cable and stuff..
Then I got thinking about how it seems like I have to floor it to get any power. So, I got out my trusty brick and put it on the gas pedal (The car was off you tools!!
). Then I walked around to the throttle body and guess what?? The throttle plate was only about 1/2 open!!??
I dunno if the cable is stretched or if the stop on the cable has gotten pushed back, or what, but it wasn't open more than 1/2.
So, I cut the end off one of those white bic pens, cut a slit down the middle and put it in the space between the cable stop and gas pedal. Used a couple of zip ties to hold it on, and now the gas pedal is almost level with the brake pedal. Also, the floor no longer stops the gas pedal, it's the throttle body that limits how far down I can push the gas..
I think I'm going to find a more permanent solution though. I'm going to replace the bic pen with a metal peice, and use hose clamps instead. Or even one of those cable clamps..
So, yeah.. 20 minutes and I have my power back, and maybe even more than I had to start out with!!
Riley
Plugs.. Look good
). Then I walked around to the throttle body and guess what?? The throttle plate was only about 1/2 open!!?? I dunno if the cable is stretched or if the stop on the cable has gotten pushed back, or what, but it wasn't open more than 1/2.
Riley
so bad that it was in everyone's interest just to forget about it... Less trauma
