Gasket Scraper or razor blade?
jaymac
995
Northern Mass
I'm getting ready for my head swap, and notice when I was scraping the lower to prep it, the razor blade could catch and gouge at the aluminum on the egdes, and had a hard time getting everything off. Obviously the block is iron so gouging shouldn't be a problem, but when I do get to cleaning the block, should I use a gasket scraper, the solid metal ones w/ a handle like a screwdriver, or just a razor blade?
Also, I got MEK, now how should I apply it for best results? Rag? Soak? Rub? Brillo?
Any tips would be appreciated!
Thanks!
Jeremy
For aluminum stuff spray the gasket with brakekleen or carb cleaner. Then use a razor blade but pull it BACKWARDS so you don't gouge the aluminum. It works great. For the block I use a pnumatic gringer with a SOS pad like deal on it or a regular gasket scraper.
Thanks!
Jeremy
Both will work and both can gouge your block, it is more how you use them. I would vote for a gasket scraper with a handle, it is a lot easier than gripping a razor blade with three fingers.
For aluminium, I like to use a bronze wire wheel on a die grinder. But if you don't have one, a razor blade held at a relatively horizontal angle will work fine. You won't gouge the metal unless you're really going at it.
when i took my olde headers off my stock block, i used a razor blade and 40 grit fine sandpaper. the razor blade was flat as was te handle to the blade. i went to autozone b4 to ask for a gasket scrapper, were i was asked what a gasket was.
no, i tihnk the best was i bought a slide hammer there and they asked what i was doing to my car. i said changing my clutch, and im going to put in a new pilotbearing. then to which i was asked,"is it manual or automatic"
Gasket scraping sucks no matter what you use lol. I have used both. I deinfately would recommend the handle if you're going to use razor blades. I really can't say one is better than the other.
I guess I'm lucky, the people at autozone here know a little about cars and have helped me with a few things. I guess some of them could be morons.
My favorite tool (that I now ONLY use for scraping gaskets) is a pretty little 4" pocket knife that my x-wife got fr me years ago. The blade is very wide which is great for laying it flat along the surface that I'm scraping. The blade is fairly dull and would not cut paper or string or much of anything else for that matter, very well. It DOES have an edge on it though (If that makes sense. I can't think of a way to describe that better). It's dull enough that it does not scratch up the surface but sharp enough that it slides between the metal and the gasket material. It works pretty well. I just use a wire brush to clean up the tiny little stuff that's left behind.
