gauge install help plz
  • Thread starter Thread starter 93GTosu
  • Start date Start date Jul 28, 2006
93GTosu
183
  • Jul 28, 2006
ok, i bought 2 Autometer gauges: water temp and oil pressure. I've been browsing through search results but its easier to just post my questions...Both gauges are electric btw. Autometer sport-comp or somethin.
1. Where can i ground them? Do i route the 2 grounds through the firewall also? And if so where can i ground them? With another ground? should i ground them together?
2. I need to hook the gauge itself up to an electric source and the lightbulb up to a switched source. I am tapping into the fusebox (#13 i believe) for the bulb so when i turn on the headlights the bulb lights right?? What do i hook the gauge to then???
3. Where is the sending unit for the oil pressure.......
Thanks guys...tell me if im goin about somethin wrong!
HISSIN50
34
129
Jul 28, 2006
  • Jul 28, 2006
You can connect all the grounds for the gauges together (the two lighting grounds and both gauge grounds). Then run one wire from where you connected all 4 wires together, to a solid ground. Any bolt on shiny metal should suffice (where you're gauges are being mounted will determine this). No need to run the grounds to the negative battery terminal as some instructions indicate.
You will want to find a 12 volt source that's hot only with the key turned on. Again, location determines this most of the time. A source from the fusebox is always easy.
You got the positive wire for the lightning nailed. If your gauges are near the radio and your radio harness has an illumination wire that works, you could tap into that (or at the HVAC lighting wiring). Fuse 13 is real easy though if that's preferred.
The sending unit for oil pressure is above your oil filter. The stocker screws into a hex tube lookin deal, and the stock sender looks like a bell.
You can use a tee for the OP senders if you like.
For the water temp gauge, I'd put the new guage's sender in the stock location. Then move the stock sender somewhere else (rear of the intake manifold, into a tapped T-stat housing, etc). You want your most accurate gauge to read from the stock location. And you should not use a tee for temp guages (hence jumping through those hoops).
Good luck and enjoy!
93GTosu
183
  • Jul 28, 2006
Thank you very much sir!!!!! everything i needed to know!!!
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
M
  • mnky99
  • Sep 5, 2025
mnky99
M
