  • 2005 - 2009 Specific Tech
Gear Chart
  • Thread starter Thread starter bynumj
  • Start date Start date Sep 4, 2009
bynumj
77
Portland
Sep 4, 2009
  • Sep 4, 2009
I keep seeing questions about gears and RPM on here so here is a gear selection chart that should help. The chart will let you select tire size, gear ratio, transmission, and speeds. I hope it is helpful. To get the chart to work, change the .txt to .xls for the Microsoft excel file or use the open with excel feature.
  • Gear_Chart.txt
    Gear_Chart.txt
2010 GT MAN
18
N.Y.
Sep 4, 2009
  • Sep 4, 2009
FILE
This file looks corrupt
bynumj
77
Portland
Sep 4, 2009
  • Sep 4, 2009
You have to save the file and change the extension to .xls because this site will not let you download an .xls file.
89StangGT50
178
TX
Sep 5, 2009
  • Sep 5, 2009
This chart is AWESOME...big props for posting it.
I couldnt decide between 3.73 and 4.10 because I do still drive a lot on the highway even tho I want a quick 1/4 car. I was concerned Id be pissing through gas with the 4.10s driving at a usual 75-80mph
I def. think this should be a sticky...it would get rid of a TON of gears threads!
89StangGT50
178
TX
Sep 5, 2009
  • Sep 5, 2009
im not sure if you were the one who made the chart, but would it be possible to add the stock gears on there too, so you can get a real good idea on comparisons
the 3.31 and the 3.55s?
bynumj
77
Portland
Sep 6, 2009
  • Sep 6, 2009
If you changed the file to an Excel file (.xls) or used the "open with Excel" and saved as an Excel file, you should see a pull down menu for the highlighted areas that allow you to change the gear ratios. If the pull downs are not there, let me know.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
