gear debate
uhoh5.0
354
Montgomery, AL
What is the steepest set of gears you could go with in an auto if you are planning on possibly doing a power adder (supercharger) down the road? 3.90? ALso, I know there is always a debate about what gear to go with, but in my last mustang (in sig) the 4.10s made interstate driving kinda rough. I got horrible gas mileage and I was around 3500rpms at about 60ish mph. I just don't want to lose driveability, but I still want the seat of the pants hp feeling that gears give you. I went from 2.73s to 4.10s in the last stang and that was a HUGE :D difference. And finally, does FRPP make a 3.90 ratio or would I have to go with motive, which leads to my final question: Are any gears other than FRPP ok? I've always heard to stay away from other brands.
Thanks,
Sean
3.73, maybe 4.10
Do not fear the gear :shrug:
No, FRPP does not make a 3.90
It is not about the brand of the gear it is about the quality of the install. However, FRPP gears are easier to install because you can use the MHD (master housing depth) method.
Also, you could have found the answer to these questions by doing a quick search...
What would I tach in OD with 4.10s? 3.90s? 3.73s?
And most importantly, if I am correct (and please correct me if I am wrong) a set of 4.10s should add roughly 2 to 3 tenths in the quarter mile. :shrug:
So, with going from 3.27 to 4.10 thats a difference of 0.83 in gear ratio. So, as a percentage 3.90s should add roughly 75% of that 2 to 3 tenths which would equal somewhere between .15 and .225 sec and 3.73 would be roughly 46% and somewhere between .1 and .15 seconds. So, to round and make it easy you could say 4.10s=.3 tenths 3.90s=.2 tenths 3.73s=.1 tenth ???
Don't know if thats an accurate way to predict performance gains, but it make sense at least on paper.
04YELLOWGT said:
I have a SC and have 4.10. They work perfect because it gets you into the boost quicker.
4.10's wont be good with kenne bell S/c's. 4.10's work with your set up because you have a centrifugal SC.
I'd stick with 3.73's if you plan on using a power adder..
.3-.5 off your quarter mile. Depends on the tires you have and how well you hook...
to me this is the bottom line.
if you keep the stock 6000rpm limiter you will have like 112mph trap speed if you go 4.10's.
you will have like 120mph of trap speed with 3.73's.
so based on that info is how I would pick the gears.
If my wife quits spending my money I am getting the kb 9psi kit. so i went with 3.73's because I feared getting really close to redline in 4th by the end of the quarter mile.
if the blower you are going to buy does not give you enough power to trap over 110 or more you may consider 4.10's. if you plan on making say 400hp at the wheels or so you may consider 3.73's. you don't want to have to use overdrive before the end of the 1/4mile it will hurt your et.
Cantslowdown said:
I have 3.73s and i have automatic and I am right at 2400rpms doing 70..I think 3.73s in automatic is a good combo alot will say 4.10s but if ur car is a dd then 3.73s is just right..
4.10's Auto in OD. Stock tire size. 4.10's are perfect in an auto!
