I installed them myself. I use a ProForm pinion depth tool and used FRPP 373 gears. The pinion depth tool showed that I needed a .029 shim on the pinion and the factory was .028, so I used the factory shim, which a lot of guys on here say if you use FRPP gears they always use the factory pinion shim. The backlash I set at .008, which is suppose to be .008-.012. It took me forever to get the backlash correct, but I did it until it was right on and I used a dial indicator and magnetic base. I did install a new Eaton locker, could this be my problem? Do I just need to be patient and let things break in? My problem with narrowing the problem is I did so many things at one time. I changed locker, gears, axles, bearings, to disc brakes, new brake lines, upper and lower control arms, springs, shocks, etc. Anybody know what may be the deal? I did put all spherical bearing control arms, so everything is SOLID! I just still feel like in reverse though it is too loud of a whine.
