My car is a '66 GT Fastback, automatic, nice condition, only non easily reversible mod so far is subframe connectors. I'm just installing a new 342 crate engine - 450hp, 420ft ft lb torque and am going to change the car out to a manual gearbox at the same time.
I live in New Zealand and we have very few freeways here, mostly twisty winding canyon type roads. Most of my driving is under 1 hour in duration, very little long distance driving. My car is well set up in suspension and braking, and my driving is mostly 'canyon blasting' for weekend fun. The car is not a daily driver.
By the time I import a manual gearbox changeover kit from the U.S., the cost of a Top Loader, T5, or TKO 500 kit ends up being close enough to each other that cost isn't the deciding factor. All options have benefits and drawbacks:
Top Loader - will handle the hp, originality-no mods to car, but no 5 speed
T5 - marginal for hp if not G Force, minor car mods, offers 5 spd
TKO 500 - will handle hp, involves trans tunnel bracing cutting mods, 5 speed
Which gearbox would you use ?
) Also consider what bell housing, the TKO and Toploader use the same bolt pattern, but the TKO requires a deeper bell for it's longer input shaft. The stock Toploader bells will work with it using a 1" spacer.
