Gem module
Cws
Arizona
I have a 2004 V6. My gem module went bad and is not repairable. The repair place said I have to program the replacement. Is this something that I can do or does a dealer have to?
Here's something that MAY help.
ForScan ODB2 scanner w ELM327 USB
https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
There is also a possibility that the autoenginuity ODB2 can do the job. Do your homework.
https://www.autoenginuity.com/
The other option is to go to car-part.com for a replacement GEM and replace it yourself. Then find a local shop with a J2534 programmer that can do it for you.
Or my Ford Service manual does not list the re-programming as a requirement for the replacement of the GEM. So maybe the dealer isn't being "truthful".
Note, Ford does sell access to full dealer service on a short term basis. It's not too expensive if you have the correct Ford tool. Look at the 72 hour option ($29.95)
https://www.motorcraftservice.com/Purchase/ViewProduct
Finally there's the dealer for the re-programming.
Thanks for the help. But I replaced the old gem and had ford flash it. As far as I can tell the problem is still there. I have a 0.25 amp draw. when I take out the number 6 fuse under the hood it goes to zero. What else could be the problem? Thanks
Need to confirm EXACTLY which fuse is in question using the numbering from the following link It does make a difference if fuse F1 (Engine bay) or F2. (central junction box).
For example. IF the fuse in question is actually F1.6, then this fuse feeds several other fuses. More trouble shooting needed.
1999-2004 MY fuse panel schedule:
https://www.allfordmustangs.com/for...r-swap-wont-fire-please-help.html#post2669271
