Getting out........
Cwalk
78
Virginia Beach, Va
Next week I'll be getting out of the Navy. So it looks like I can start my build the end of this month. I was going to do a 347. But I found a 331 about $300 cheaper. Im shooting for 475hp. I using a TFS stage 2 cam, Victor Jr. heads, a Performer RPM II intake and a 75mm throttlebody. Hopefully this will get me to my goal. Once I remove the smog pump, A/C and convert to an electric water pump. I will also be converting from speed density to mass air. Will I be able to use an X3Z as long as it is called for the 30lb injectors I plan on using?
theres only one way to find out... i can tell you really want to do this combo, and you set your goals at a respectable level!, and reachable.. there will be those who doubt and those who agree.. so do the combo and dyno.... thats it,.. plz post results!!!
Thanks for the vote of confidence. I will post numbers as soon as the build is done. I may have to change the spring out on the head. Because Im using 1.72 Scorpion RR's instead of the 1.6's. Matter of fact I will. The lift is already over .500 with a 1.6.
i dont think you'll hit those #'s dead nuts but it will be up there, sounds like a nice combo! i just think 475 is a little much... but like i said its gonna be close, im 100% sure that it will land in between (you 475) and (grey370)... im gonna go around 371 and 420.... and if you get 475 its because you lied and did somthing differant...
To get the most advantages out of the parts you are going to buy, see an engine builder and match the parts to go with each other (look into the specs). My buddy is buildin a 331 Sportsman with Scat crank, Scat H Beams, Wiseco 9.0 : 1 pistons. AFR 185's some crane cam an a air gap intake with a DEMON 750 or somethin. Guestimated at 480 crank HP, and 420 to the wheels, AN he setup up the motor for a 125 shot.
*sigh* I hate the mentality that power adders are the only way to get that kind of numbers... Totally not true. Its all in the little details.
Sounds like anyway you slice it you'll have a stout setup though.
475 will be tough to achieve with those parts IMO....but if you are going to pass up 16 cubic inches on a bigger stroker kit to save $300 you maybe in the wrong hobby.
I think you might want to look at a differnt head/cam combo if you really want 475hp
I agree with you. I hate to see people with power adders post numbers in the 400-500HP range. You can do it NA. Its not really impressive to me.
power adders are there for a reason big power numbers and motors that do not have to be set on kill, cam shafts with 600 lift are not exacty streetable for the most part nor is 110 octane to go along with your 13:1 compression, and you want to make 475 but passed up on the 347????? seriously the 331 was designed with a power adder in mind, becuase with no power adder there is no replacment for displacment!!!! and i will catch a magic pony and ride it to the enchated forest and get a lapdance from snowwhite before you build a 475 horse 331 based combo, and you realize of course that at that power level the stock block will split in half
