Getting Ready To Put The Engine Back Together. Quick Question.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
When I put the heads back on, all I really need to do is turn the engine over until cylinder 1 is at TDC and then put the distributor where the rotor is pointing at the #1 contact. Right at 12 o'clock IIRC. Sound about right?
  • Sponsors(?)
Dan_Soprano
Mod Dude
May 7, 2003
7,406
43
129
41
Jacksonville, FL
Make sure it is TDC on the #1 compression stroke. AKA turn it over until the #1 intake valve starts to close. When the #1 piston is at TDC after the intake valve closes you are good to set your distributor as stated above.
The Green GT
1,269
Louisiana
Can I turn it to TDC before I put the heads on? seems like I could just watch the lifters to see which one moves so I know which stroke its on.
Dan_Soprano
Mod Dude
May 7, 2003
7,406
43
129
41
Jacksonville, FL
its the one closest to you (front) on a SBF Windsor #1 cylinder. If you ever get confused, just look at the intake or exhaust port in relation to the corresponding valve.
jozsefsz
5 Year Member
Aug 11, 2013
1,144
271
114
49
Cleveland OH Area
If you can't watch the valves easily (heads / valve covers already on) just place a rag next to the spark-plug-hole on #1. When it gets puffed out of the way by air, you're on the compression stroke.
Thread starter Similar threads Forum Replies Date
Gunmonkey Forced Induction 93 with HCI. Getting ready to supercharge. Anything I should upgrade internally first? Fox 5.0 Mustang Tech 8
kmcgr6 Digital Tuning Im Getting Ready To Do My Hci Change And In Need Of A Dyno Tune. Fox 5.0 Mustang Tech 0
G Fox Help - Trying To Get Ready For Power Tour 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
JH96GT Getting Ready To Install Two Full Length Floor Pans...any Tips? Classic Mustang Specific Tech 21
Detroiit Fox Getting Ready For Dyno Tune Tomorrow!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 39
OonDeanisS Getting Ready To Pull My Motor... Tdc Question. Fox 5.0 Mustang Tech 4
Chris98Stang Getting Ready To Buy A Teksid 4.6 Block, Many Questions On Build And Fi SN95 4.6L Mustang Tech 28
R Engine Getting ready to build one Classic Mustang Specific Tech 7
90GTFIVO Getting 90gt Ready For Dyno/tune Shop Fox 5.0 Mustang Tech 22
T Engine Getting Ready To Mod, But Concerned. 1994 - 1995 Specific Tech 1
boostfrk Getting Ready To Paint Interior Plastics...prep Questions Fox 5.0 Mustang Tech 7
1 getting ready to lower the cobra... need help SN95 4.6L Mustang Tech 1
dewwy5.0 Getting Ready to buy a 94 or 95 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
G Getting ready to replace lower ball joints on my 04 GT... SN95 4.6L Mustang Tech 1
myslo50 getting ready for paint 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M Getting engine ready for heads cam Fox 5.0 Mustang Tech 1
T 5 lug swap getting ready to start what axle seals to use?? Fox 5.0 Mustang Tech 1
S Getting ready to start stroker project The Welcome Wagon 3
banks getting ready to do rear suspension Fox 5.0 Mustang Tech 5
K Getting ready to buy...... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
BlownStangGT Getting ready for the track... 1996 - 2004 SN95 Mustang -General/Talk- 7
2 Getting ready for nitrous SN95 4.6L Mustang Tech 11
NastyStang113 Ready to get tuned? .. or dyno'd? 2005 - 2014 S-197 Mustang -General/Talk- 9
0 Getting ready to build my 5.0...some questions Fox 5.0 Mustang Tech 19
9 Getting ready to order C&L Plenum, have question SN95 4.6L Mustang Tech 6
G getting ready to start 347 1994 - 1995 Specific Tech 2
Tom95gt Getting ready to install new carpet 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
N pics of my car getting ready for paint 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mach1Run Getting ready to install a line lock SN95 4.6L Mustang Tech 1
F getting ready to get this thing together Classic Mustang Specific Tech 9
P Getting ready to make my Order from Summit for my EFI to Carb Swap... Fox 5.0 Mustang Tech 3
9 Getting ready for some racing Regional Forums and Event Information 3
stang1986GT Getting ready to replace head gaskets...any tips? Fox 5.0 Mustang Tech 9
S I think my idler pulley is getting ready to die *Video* SN95 4.6L Mustang Tech 27
yellowstang1994 Getting ready to pull engine, help me figure out what I should do. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
68converted Advice: getting ready to start up the 5.0 swap Classic Mustang Specific Tech 15
Roland69 getting the 884cyl coupe ready for the road 86GT and 884cyl interchange Fox 5.0 Mustang Tech 1
Aliate X Get ready to cry. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
W Getting Ready for the Vortech :D Fox 5.0 Mustang Tech 12
fivespeedsteed getting ready to leave the car sit for a few months. what to do... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
sicK96GT get ready to wet pants (warning: extremely graphic) 1996 - 2004 SN95 Mustang -General/Talk- 17
degins CSRP SWAP.2 Get Ready For Spring Special Classic Mustang Specific Tech 0
Orange... Slowly getting ready for... 1996 - 2004 SN95 Mustang -General/Talk- 5
04YELLOWGT Getting Ready To Order MMR MOD 600. SN95 4.6L Mustang Tech 4
5.02GO Getting ready to purchase a Scat 306 rotating assembly Fox 5.0 Mustang Tech 10
carbed87 ok, getting ready to buy a re-man motor, what should get beefed up to run a BD11 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Black Sun 5.0 Getting ready to start the project Fox 5.0 Mustang Tech 4
3 Getting ready to build my rear end Classic Mustang Specific Tech 1
badstang123 Getting Ready to Order Upper, Lower, and Throttle body. Help Me Out! 1994 - 1995 Specific Tech 4
Nopantz getting ready to order more parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
