  • 2.3L (N/A & Turbo) Tech
Getting some input
  • Thread starter Thread starter RoD2120
  • Start date Start date Jun 8, 2004
R
RoD2120
14
  • Jun 8, 2004
I'm not quite happy with the NA 2.3L in my 93 LX hatchback, so ive decided this summer to swap in a 351 Cleveland and a C6 (small BH) transmission. I'm not going to stay EFI unless i decide to fork up the cash for a holley programmable system like my dad got for his truck.
I know the harness will need modification, better rad, etc but i have some small questions:
Will the 5.0 engine mounts work? From what i understand i actually have 5.0 mounts with a 5.0 to 2.3 adapter, so just pulling off the adapter gives me 5.0 mounts?
Should i re-route the break lines?
I'm not looking for alot of really into-it info, just a general idea what i should start looking into. I have alot of experience with engine swaps (i put a 454/700R4 in a jeep wrangler, a 13b rotary in a plymoth sundance, etc.), and since i work @ Advance i have easy access to discounted parts
140cilx
2,385
GA
Jun 8, 2004
  • Jun 8, 2004
This one made me laugh.
I dunno, should you? Do you want to?
Just start getting some measurements and make some mounts and get busy.
Dr_EluSivE
2,155
Central Illinois
Jun 8, 2004
  • Jun 8, 2004
I would only Reroute the brake lines if you break them installing the motor. broke brakes dont work.
Dr.
R
RoD2120
14
  • Jun 8, 2004
Well the reason i ask is because when dropping in a 5.0 its suggested that you run the lines down the other side of the vehicle but it doesnt explain why. I assume its the same suggestion for a 351 but i figured i would ask.
bhuff30
6,037
35
129
Olathe KS
Jun 8, 2004
  • Jun 8, 2004
probably because the exhaust is kinda close to it, but the biggest problem is the line is right where the left exhaust tries to go over the axle.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Jun 8, 2004
  • Jun 8, 2004
How in the hell did you get a rotary to work in a sundance? I wanna hear about this one.
R
RoD2120
14
  • Jun 8, 2004
We took a carb-fed 13B from an 86 non-turbo, along with the trans and set it aside. We have no electronics at all in the thing but its totally stripped interior wise, only has a rpm guage and a speedo. We had to fab motor and trans mounts which took three or four tries to get right, that was the hardest thing.
Took the shaft up to RWAY Tooling and had it custom made to match the plymouth rear as well as the mazda transmission. The radiator was taken out of the RX7 as well because it was a three-core rad.
There was alot more involved, and almost 4.5 months. When jim (the owner) gets back from florida on the 22nd ill get over to his garage and take picstures.
F
Getting my old autocrosser running again
  • flightops
  • Aug 28, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 28, 2025
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
