RaceDvr50 said:
WTF? Remove the stat if you want, the more coolant you move through the engine the better. The radiator is a heat exchanger it absorbs and disperses heat by transferring it the the air it doesn't hold the coolant and wait to release it until it cools. If you can pull the radiator cap and watch a healthy wash of coolant flow through the radiator you are probably golden as far as flow goes. Then look for something else, is this a stock fan? I have seen someone put in a fan that was pitched the wrong way and it stalled the air going into the radiator and overheated quickly. Also, do you run cats? A plugged cat can cause a hot running engine.
I am not trying to say that excessive flow is the source of this guys problem. I am just saying that this is a possible condition.
Think of it this way. If you had to grab a hold of something bare handed that you thought would be hot enough to burn you, what would you do?
Most likely you would touch your hand to it very quickly. The less time you spend in contact with the hot object, the less heat will be transferred to your hand.
Heat transfer is a function of time.
Another example... A hot cup of coffee will not cool to room temp instantly. Time is needed to transfer heat from the coffe, into the cup, then into the surrounding air.
It is the job of the t-stat to slow the flow of coolant through the radiator. Not only does it only open when the coolant reaches a "warm" temp, but the stat also acts a restrictor even when the stat is fully open.
Several guys have posted here about having trouble with keeping their coolant temps down. A few questions later and we find that they had removed the t-stat completely.
I also seem to remember a few instances where removing the stat was all a guy could do to keep temps down (this was in very hot parts of the country though).
:OT:
JT- I have not read anything on that 6 stroke engine. Thanks for bringing it up though
I will look into it.
jason
