Going Cams..Valve Springs?
SCalla1384
33
Hey guys, so Im getting ready to order my HiTech Stage 2 Cams. Probally by the end of this month or I may just wait til the end of october.
With the HiTech stage 2's it says I do not need Valve Springs unless I operate above 6,400rpm. Which i dont plan on doing.
I have about 72k miles on my 03 GT. Should I get valve springs? I really hope I dont. Because Im bringing it to the shop to have it done. Itll get done quicker and its my DD. And valve springs would be $200, plus another $600 for labor. That would suckkkkkkk...Will I need them or will I be fine? Thanks for the help guys.
$600 for labor for valve springs? That seems a bit high... Especially being in there already for cams.
Edit: I see lots of red Mustangs in here :p
speaking as a red mustang owner ;)
labor for head rebuilds is high because they are complicated heads, with 32 valves and springs. Not to justify it, since I just got taken for $2k to rebuild a set of heads with a stage 1 port. If I had gotten out the door with only 600 in labor I would have been happy...
True I didn't think of that, my experience is mostly with OHV engines... where heads only get as complicated as 16 valves, springs and rockers. :)
The 2V GT only has 16 valves.
The only real complication/difference between the modular 2V head and a standard OHV head is the camshaft being right there. After it's removed, access to the valves and springs isn't much different than an OHV design.
I would suggest going with new valve springs on any aftermarket cam. It is money well spent. You might pay a little more up front, but it can save you in the long run. I have been on the other side of spring failure after a set of 2v cams, and it trashed my motor. Good luck.
FWIW, I've been running stock springs with Comp 262AHs (226I/230E duration @ 0.050 and 0.545 lift) for a couple of years now with no issues. 'Course, I also make a point of not revving the piss out of the engine too...
+1, I'd do it just to be on the safe side especially on a set of aftermarket cams.
