going carbed, (dont ask why, I have my reasons)
My questions would be:
Do i really need a new fuel pickup?? if so why cant i reuse my efi pickup?
Can i use my old distributor?
something that may make you really scratch your heads is that i have a SLIDER motor, not a roller motor.
Im not sure if that will make a difference or not, but I thought I would put it out there.
The carb system im going with is a holley 750 double pumper w/ mechanical secondary and a edelbrock air-gap rpm intake. also a holley blue pump w/ regulator (as i stated before)
Also, what else Might I need ignition wise??
Anything Im missing????
(I have the wiring part down pat, so dont worry about that)
Heres the setup I will be using
1993 ford mustang gt convertible zero miles
New 306 SLIDER block, 1.72 crane roller rockers, Competition cams 280 camshaft, Forged rods and pistons, offroad h-pipe, Flowmasters, K&N filter, Trick Flow Trac-Heat Twisted wedge heads, BBK shorty headers, Centerforce clutch, Metal quadrant, hurst shifter, Mrgasket engine set, 3:55 gears, Edelbrock Air-Gap intake, holley double pumper 750 carb w/ mechanical 2nds, Lightened pulleys, Alluminum driveshaft, Race Pro Aluminum Radiator
thanks in advance, if anybody can even answer this, LOL
-Dan
-Dan
