Dont know if I should post this here or "5.0L Talk" but I will soon be coming into some extra money about $3000-$3500(MAX I want to spend), and would like to know if I could make it into the 11-12sec times?
I've already got a '90 hatch/manual LX with supposly 92,000miles sitting at my bro's body shop waiting for it to get painted that I got for $900, so far I found out it has upgraded spark plug wires/distrubutor, 65mm TB(edlebrock?), some kind of short shifter, flowmaster muffs with unknown SS H-pipes with 2.5" piping, pretty grabby clutch(previous owner said it was replaced), and I believe rear end gears cause it just seems to spin these cheesy lookin 15's easier in 2nd than 1st
, plus im always in 2nd/3rd while just driving it around the block, but I have yet to get underneath and check.
I would eventually like to go turbo i've seen a few at the local dragway and just love them but for now i'd like to go all motor with 100-150 dry shot, from there I wouldnt know where to start, I was looking on dragtimes.com and most 11-12sec N20 fox bodies are running AFR heads with E303/F303 cams or AFR cams I believe is this a good setup? And about how much do these heads usually go for? What intake manifold would go good with my 65mm TB? Would investing in a detriot locker with 31spline axles be a good investment when running drag radials/slicks? How long would a stock T5 take this setup for?
As far as tires i've read many mixed results on the M/T's 15" tires, are the 255's street drags too much for stock rearend? Would the 235's still grab for a good 60ft?
, plus im always in 2nd/3rd while just driving it around the block, but I have yet to get underneath and check.I would eventually like to go turbo i've seen a few at the local dragway and just love them but for now i'd like to go all motor with 100-150 dry shot, from there I wouldnt know where to start, I was looking on dragtimes.com and most 11-12sec N20 fox bodies are running AFR heads with E303/F303 cams or AFR cams I believe is this a good setup? And about how much do these heads usually go for? What intake manifold would go good with my 65mm TB? Would investing in a detriot locker with 31spline axles be a good investment when running drag radials/slicks? How long would a stock T5 take this setup for?
, I know as far as compression and cam options they will be totally different when it comes down to boosting it the right way and getting it tuned right with a proper rebuilt/crate motor to run a turbo setup. I was also reading the stock headers arent really much of a restriction when it comes to N/A power on a stock 302 block, plus when I go turbo eventually i'd lose whatever headers I had bought because most kits i've seen already come with custom headers for the turbo setup.
