Going to the track
Holik95
90
Granite City,IL
I'm going to the track today and have a few questions. First, I have to run on street tires so what should I set my psi at? Or does it matter? I can't put my Nittos on cause I stripped a couple of studs. Should I go through the water box? Or should I go around it? Will it help to do a burnout?
drive around it and back into it so you dont drag water all over with your front tires. with street tires you dont have to do a super long burnout, just a lil quick one to clean up the tires
you can lower your tire pressure to 25-26 and see if that helps
