I don't know that I would bother with all the machine work on the bottom end that you're talking about. Getting a stroker kit these days is so cheap, that it would almost be pissing away money to grind the crank and just put new pistons in. If your motor is healthy right now, maybe just put new rings and bearings in it at the most. Save your money for better things.
I agree with these guys though:
Definitely 255 lph fuel pump, skip anything smaller.
New stock replacement oil pump, nothing more, nothing less.
I would say take it a step further on the cam, you can definitely do better than the ones you've listed. I like the Comp XE line of cams. Maybe a XE266 or 270, or maybe a 274 if you want something a little more aggressive. You can call Comp and have them help you select a cam, too. Get a matching set of roller rockers and springs.
You can go with the Explorer 65mm TB, but I will say that an aftermarket 70mm TB lines up nearly perfectly with the stock Explorer intake opening. Just something to think about.
You should look at THIS THREAD. It can be found inside Fox talk's really common questions thread:
http://www.stangnet.com/mustang-forums/threads/fox-talks-really-common-questions-thread.825480/
