Got my car started today....suh-weet
Red_LX
I’m not much help unless you’re looking for ****!
Yep finally, after a week or so of fiddling with it, I finally got my new engine to actually run. I ended up pulling the distributor off my old engine and dropping it in, and it fired right up. After I got the timing set, it runs good, oil pressure is good, pulling 18-20" of vacuum. Unfortunately, my cooling fans weren't kicking on and the engine was over 200 degrees so I shut it off until I could figure out what the problem was there. Looks to be something with my adjustable fan controller because I bypassed the relays and the fans kick on. guess I'll get it figured out eventually. I'm pretty stoked though!
Nice. I got my Turbo motor running a few weeks ago, but that was in NON turbo form. I too Hope to have my turboed motor running in the next week or so. I just need to get it all plumbed and fire it up. I hate having to spend most of my day working.. i could get this done alot faster!!!!
Dr.
Well today I took the car out for a drive, seems to run quite well. The BOV is loud even at 10 psi :nice: I seem to be having some problems with the IAC though, car keeps wanting to shut off when I push in the clutch while slowing down.
And I was gonna take some pics today, but it started raining and I didn't get a chance to. I'll try to remember to get some on wednesday.
Ok ok...I just ran out and took a couple pics. Also found a small puddle of coolant on the ground. I cannot get the damn thermostat housing on this thing to seal :fuss: Guess I'll have to get the coolant level much lower than the head and try it again, that must be my problem.
attachment.php
attachment.php
same problem I had with the temporary engine in my 88. damn thing leaked no matter what I did. oh well, I yanked that head off anyway.
how pitted is the housing where the heater hose attaches??
Well, what the problem has been is that I modified my thermostat housing, and it was sealed up good at first but I had to pull it off to fix something else, and every time I took it off there was just a little bit of coolant on the gasket surface (on the head) near the bottom when I reinstalled it, and I'm fairly sure this is what was allowing it to leak. So last night I drained the coolant down and made sure it was well below the thermostat hole, and wiped the surfaces down with mineral spirits. I hope this gets it.
Ash: Here ya go. I just welded a little piece of 1" pipe to my IC pipe, and I have the BOV clamped to that.
attachment.php
