noToms_2003_Stang said:Is it necessary to uncouple the fuel line connector from the fuel rail?
coramprat said:The speed sensor will be hard to remove because it is lock tited in and it is hard to get a good bite on it with a philipps screwdriver without tearing it up.
GDawg said:My Accufab TB did not come with a TPS.
SilverGTV8 said:I have never seen the TPS sensor come with a TB.
CaliLifeStyle said:Unless you get the Ford Racing TB. It comes with a new TPS already installed.
SilverGTV8 said:You said this wrong,
Unless you but a Ford racing TB, YOU will need to transfer the TPS. Is what I think you wanted to say seeing as you posted links to FMS TBs.
Testing the voltage range on it will tell you if it is good or bad. Not really adjustable. But you do need to make sure the the TB blade is resting on the tabs inside of the TPS. This may require you to insert the blade so that it does engage the tabs and twist it to line up the mounting screws.shotime said:Is adjusting the voltage on the TPS necesary on all TB installtions? How do you "adjust" it once you figure out what the voltage is?
