Got My Saleen SC Wheels
:rlaugh: i was wondering if i was the only one who noticed the gnarly linoleum floor.
Its carpet in my parents basement :D
Love the wheels. I've been thinking about them myself in silver though. Can't decide on 17x8 or 17x9 up front. I think the 17x8's look too flat.
Thats why I went with 17x9 I thought the 17x8s looked to flat too
I had the 17x9's up front but too much rubbing so I went to 17x8's. I have 245/45 up front and no rubbing issues with h&r sports.
I have some rubbing to, on the front lower part of the fender well, Im going to do something to make it work, not sure how yet. They also will hit the control arm at full lock, but I have some rack limiters coming to fix that problem.
How do you install rack limiters, it cant be that hard but Ive never seen or read how its done?
I got my 17x10s.
I have a problem with my front 17x9s though, when I turn the front wheels they hit the front edge of the fender extension by like 1/4 of an inch. Anybody else have this problem? Anybody have any ideas to help my problem? Im thinking about trimming it but Im not sure.
Im been also looking around for some tires 285/40/17.
Anybody ever run Cooper Zeon 2xs?
How did you like them?
Ive also been looking at some kumho escta spt and kumho escta asx.
I got my 17x10s.
mine do that too, im still running the stock 89 fenders though. it looks like the 91-93 fenders and extensions should clear them though (wider right in this area). you may be able to trim the fender and run the newer extensions too (dont know if they mount differently or not).
Here are some pics, only one wheels though, I have some rear tires ordered and I haven't mounted my tire on my 17x9, Im just going to wait and have them all mounted at the same time.
Heres my rubbing problem (I have some 245/45/17s on my truck rims, I might switch to)
Wow you can barely turn the wheel with out hitting.... are you using the stock K-member? why are you running 255/45's?
I run sn95 spindles 17x9 255/40 tire in the front on my 87 and mine only hit at full lock. i used a couple steering spacers to avoid this problem. Seems like you are going to have to cut the inner wheel well.
Yeah I still have the stock k member, Im trying 255/45s because I got a pair for $100, I have a pair of 245/45s Kumho MXs (there on my truck rims) that im probably going to try. I have some steering spacers to because they hit the back of the control arm.
how many inches is ur hood
3inch H.O. Fibertrends
Heres the difference between my 245/45/17 Kumho MX on left and my 255/45/17 Goodyear Eagle F1 on the right. There is quite a difference, I think its enough to fix my rubbing problem, I'm barely rubbing with the 255s
Could you measure the center cap? Also, do you think a set of those pony center caps from bullit wheels would fit? I am looking at getting these in chrome and I am not sure I like the center cap. Thanks
