Got some power issues!
  • Thread starter Thread starter boostaddict5_0
  • Start date Start date Mar 20, 2009
boostaddict5_0
37
  • Mar 20, 2009
I took on someone else's project which he pretty much cut up alot of wires. It's a 1989 Mustang hatchback chassis with a crappy 86 302 HO and a 1990 wiring harness. I finially got the car to turn over by key after finding some ignition wires had been cut. Now I chasing no power to the eec, injectors, fuel pump, power mirrors, and headlights. I've got the wiring diagrams but the main one I'm worried about is the black/orange eec power wire is non existent. I'm kinda unfamilar with foxbody wiring and locations. Oh I can't find the connector for the neutral safty switch harness coming from the AOD.
Anyone want to take swing at this?
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Mar 20, 2009
  • Mar 20, 2009
Sounds like you have your hands full.
It may be less work to just source out all new harness's from junk cars/ebay.
89 and 90 mustangs had some noticeable diferences in wiring.
Most used harness's are fairly inexpensive, so if you shop right, you may not need to spend much.
boostaddict5_0
37
  • Mar 21, 2009
found out it is a 92-93 wiring harness so I'm assuming the colors are all different.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 21, 2009
  • Mar 21, 2009
91-93 Mustang 5.0 EFI wiring diagram
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
AutoZone wiring diagrams
For 79-88 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528004e28c
For 89-93 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280069677
For 94-98 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801f5e3b
For 1999-2005 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801ef7d7
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
boostaddict5_0
37
  • Mar 24, 2009
Alright I'm scrapping the 92 wiring harness, there's just to much that has been cut. I going with a 89 wiring harness.
The next problem is that I can't find the location for the neutral safty switch harness coming from the AOD. It's a 4 pin with the white/pink and red/blue. Is it in the car or in the engine bay? I know where the clutch interrupt switch is and it's got the jumper.
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Mar 24, 2009
  • Mar 24, 2009
if you plan on keeping the car
http://cgi.ebay.com/ebaymotors/1989-Ford-Mustang-Service-Shop-Manual-Wiring-Diagrams_W0QQcmdZViewItemQQcategoryZ34221QQihZ017QQitemZ270361831459QQrdZ1QQsspagenameZWDVW
You may be able to get it on cd alot cheaper too.
These manuals pay for themselves in no time.
boostaddict5_0
37
  • Mar 25, 2009
Thanks for looking that up for me man.
boostaddict5_0
37
  • Mar 26, 2009
Alright guys I'm stumped, I'm ready to get this beast running! Here's the problem I finally have power to the computer (jumping power), but the issue is that the 91-93 wiring harness has the fuel pump relay and the wiring is totally different then the pinout. I've posted some pictures so maybe that will help. I really don't have the money to buy another harness and I've heard of this working...so what gives and what am I missing here? Obsively I can only run one fuel pump relay. But the 88 is different than the 91-93 that it looks, is that correct?
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Electrical Need some Altenator wiring help please.
  • DanB93
  • Feb 3, 2025
Fox 5.0 Mustang Tech Apr 7, 2025
Rcdgl
R
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
F
Electrical Car dosen't run without jumping the EEC IV test port
  • Fox2newedge
  • Feb 14, 2024
  • 2 3 4
9K
Fox 5.0 Mustang Tech Mar 15, 2024
Mustang5L5
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
