Granada proportioning valve
MO351
136
MO USA
I'm doing the front disc conversion on my 67 coupe and was wondering if the proportioning valves can go bad? How reliable is it to get one off of a salvaged granada?
I've never heard of a proportioning valve go bad... but since life ain't perfect I suppose its possible.
You might want to consider getting an adjustable proportioning valve from Wilwood. A little more money, but the adjustability is nice to have.
related ?
I have a question along the same lines. Is the proportioning valve necessary? I have the front brakes plumbed with a tee and the rear through an adjustable valve. I have a really soft brake pedal now that only comes up when pumped. I've bled the system on 3 seperate occasions and adjusted the rear drums (affects pedal feel) but it hasn't helped. I'm wondering if the factory valve keeps a given amout of pressure on the rear drums to keep the pedal feel up :shrug:
Yes you need a correct proportioning valve and the extra cost of an adjustable one is SOOOO worth the money. With drum/drum or disk/disk the system equals itself as all the wheels have the same kind of system. With disk/drum it takes a different amount of pressure to make the disks work and for the drums to work. so you use it to balance out the system. I have been telling people since I did mine that an adjustable one lets you dial in your setup and takes away all the variables of trying to get the right one for your engine/year/brake/tire setup.
MO351 said:
So going with an adjustable proportioning valve like this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33564&item=7945134458&rd=1 is the way to go, eh? If so I'll just get one of them instead of the Granada valve.
Yeah, that looks about like the wilwood one I have. The price is about what I got it for. Check summitt and jegs. Heres my setup(i have a bigger blowup if you need it):
