WHITE94COBRA said:I'm also still using my stock in tank fuel pump, but I also have an external, I added the external a few weeks after putting my h/c/I, I didnt really feel too much of a difference (sotp), but the dyno pull showed a pretty good increase In the upper rpm's.
Also my old mas went south on me, and it felt like someone cut my cars balls off!! You did do new 02's right?
I'm curious as to how you would adjust voltage levels to all the other censors, besides the TPS???????????
CManT1914 said:The O2's I'm not worried about because they are ignored under WOT, and it doesn't run great under WOT either, so it shouldn't be them. Plus I'm not getting any codes for them.
Well I'm not real worried about a fuel pump right now, and the O2's shouldn't be a problem, no codes, and still runs bad under WOT.
Adjusting voltage to other sensors? All I know is I have a Mass Air Adjuster, which is supposed to let me adjust the voltage output from the MAF, which is supposed to allow you to recalibrate it for different injectors and such.
