Ground to Computer Question. Don't ya love it?!?
dec322
401
Bham AL
Previous owner ran a wire from the neg. on the battery to the computer. It is a 4 gauge wire that starts at the neg. post, runs along the driver side of the engine bay, through the firewall at the steering column across the bottom of the dash and disappears behind the passenger side of the dashboard.
The problem, it keeps catching on the steering column and rubs on the headers. The wire is melting through and I'm having weird readings on my gauges.
Possible solution: Take the wire off the battery, drill or find a hole closer to the computer, run the wire through the firewall and connect to a good place on the chassis.
Does this sound ok? Can I connect to any solid piece of clean metal on the car? What is the purpose of this mysterious ground?
grounding is good for a myriad of puposes...continuity is paramount for electrical systems to operate properly. For the computer, it is imperative. If you don't have good grounds for the O2's, and other sensors, you could end up frying the EEC...also, the injectors are fired that way, they are constantly charged by the positive side, then the computer grounds them out when it comes time to pulse them.
If you run a good (4ga or larger) ground from the engine to the chassis-like you mentioned nice clean metal-you should be able to ground anything to nearly any metal surface...also, grounding is important for proper charging, I found this out the hard way
I know the computer ground is usually right next to where the puter mounts in the right kick panel...all I did when I swapped to FI, was drill a small pilot hole, and put a sheetmetal screw in the grounding wire end...
I like this idea. Thanks!!
Grounds are important to any electrical system, and especially to
computers.
1.) The main power ground is from engine block to battery: it is
the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G alternator needs a 4 gauge ground wire
running from the block to the chassis ground where the battery
pigtail ground connects.
The 3G has a 130 amp capacity, so
you wire the power side with 4 gauge wire. It stands to reason
that the ground side handles just a much current, so it needs to
be 4 gauge too.
Picture courtesy timewarped1972
3.) The computer has its own dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid
fumes from the battery. It is a black cylinder about 2 1/2" long
by 1" diameter with a black/lt green wire.You'll find it up next to
the starter solenoid where the wire goes into the wiring harness
4.) All the sensors have a common separate ground. This
includes the TPS, ACT, EGE, BAP, & VSS sensors.
5.) The O2 sensor heaters have their own ground (HEGO ground)
coming from the computer. This is different and separate from
the O2 sensor ground. It is in the fuel injector wiring harness and
comes out under the throttle body. It gets connected to a
manifold or head bolt.
6.) The TFI module has 2 grounds: one for the foil shield around
the wires and another for the module itself. The TFI module
ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and
runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from
the battery ground wire) uses pins 40 & 60 for all the things it
controls internally.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103#volt
for help troubleshooting voltage drops across grounds
Extra grounds are like the reserve parachute for a sky diver.
If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot
and connect together there. That eliminates any voltage drops
from grounds connected at different places. A voltage drop
between the computer ground and the alternator power ground will effectively
reduce the voltage available to the computer by the amount of the drop.
Thanks Jrichker.
I understand that each thing is grounded and has a specific place in which it is grounded. Is it ok to change where something is grounded?
For instance, I think I'm just going to pull some carpet up or pull the kick panel out of the passenger side and drill a small "pilot" hole into the firewall. Then I want to cut the 4 gauge wire going from the neg. battery terminal to the computer. I will then (using a few brand new washers and a connecting tip) attach the 4 gauge wire to the "pilot" hole with a small screw.....so instead of using 6 feet of wire that is rubbing on my headers, I'll use 8 inches of wire going from the created ground spot to the computer.
The deal is that the computer power ground doesn't come from the little wire
that taps into the body near the computer. It is two wires that are in the
wiring harness that exit near the starter solenoid and connect directly to the
battery pigtail ground. Ford must have considered it vitally important to
expend that much wire and effort to connect it directly to the battery
chassis ground point.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
The pins 40 & 60 on the computer get the ground from the wiring I just
described. I would not change that or modify the power ground scheme for
the computer.
the computer.
I understand what you mean. I don't want to change anything that Ford has done as far as their intial computer ground. I just want to change what the previous owner has done with a 4 gauge wire going to the computer from the actual battery terminal. I'm not sure if he changed the initial computer ground (the two wires you have mentioned). I'll need to check that out sometime this weekend. As far as the previous owner's action, I should be able to use the same wire he used....just a shorter portion and acheive the same thing the previous owner acheived (if anything at all)......this is more of a question....not a comment :)
Well here is some things I found out today:
1. I was able to cut the 8 gauge wire (I thought it was 4 gauge) and get it away from my steering column. Here is the pic:
2. I took off the kick panel and found that I have four wires that are not connected.....they are loose in and look like they used to be connected (maybe together). Two are Black with Orange stripe, One is Black, and one is Black with Green stripe. I haven't connected anything without some guideance from stangnet. Here is the pic:
3. The ground connections next to the washer fluid tank is intact. But one of the wires is connected to nothing. Nice, huh?
What do yall think?
See the diagram I posted for help with the wire colors. From you description, the black/orange wires are the power feed to the ECC relay and the keep alive voltage for the computer memory (pin 1). The black/green wire is the computer power ground (pin 40 & pin 60) wire that comes from the main chassis ground near the starter solenoid.
Yeah, I was looking at the diagram (good stuff) and was able to identify the wires....I'm just wondering why someone would want to cut them? I guess this is just a common theme of people doing things that they don't really understand.
Maybe this is why the previous owner had to run a new ground for the computer. The old one is cut and misplaced.
