gt 40 motor
  • Thread starter Thread starter jrmesser3
  • Start date Start date Feb 8, 2010
jrmesser3
SPOKANE WASHINGTON
Feb 8, 2010
  • Feb 8, 2010
I just bought a 99 ford explorer motor ( 5.0 with gtp heads) from the salvage yard with low miles, the question I am asking is , the oil filter extension is ugly , when I removed it there is no external threads it only has internal threads none for a normal oil filter, I have spun the center portion out , is there a replacement for this and if so where would a guy find one or do I have to run that ugly filter extension. any help you be great thanks
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 9, 2010
  • Feb 9, 2010
do a search on "oil cooler" and you should find what you need.
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
C
Engine Oil pressure issue
  • Cg’s 347
  • Jan 15, 2024
4K
Fox 5.0 Mustang Tech Mar 2, 2024
AeroCoupe
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
