gt-40's, lower and 1.7's=?
  • Thread starter Thread starter rsw007
  • Start date Start date Nov 7, 2007
rsw007
469
Lexington,SC
Nov 7, 2007
  • Nov 7, 2007
i just installed iron gt-40 heads a ported stock lower intake, 1.72 roller rockers and aftermarket ignition box.
what kind of real world gains do you guys think i shoud see in hp and et's?
88mouse
630
Mooresville nc
Nov 7, 2007
  • Nov 7, 2007
stock intake still? If so that is killing you. Get a intake and cam then you will put down some good #'s.
85ragtop
BTW, I like dudes.
475
123
NC
Nov 7, 2007
  • Nov 7, 2007
Moved to talk.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 7, 2007
  • Nov 7, 2007
As it sits, probably another 30hp to the flywheel.
bloopbloob
578
Alberta
Nov 7, 2007
  • Nov 7, 2007
the lower is ported, which is the most restrictive part on the stock intake.
i'm thinking maybe + 25-30 to the wheels
rsw007
469
Lexington,SC
Nov 8, 2007
  • Nov 8, 2007
yes i massively ported the lower it should flow 180 plus in all runners. and i opened the throttle body opening on the upper to 70mm
im hoping for atleast 11.3's on the 125 shot
stykthyn
5,232
2,652
223
gainesville
Nov 8, 2007
  • Nov 8, 2007
you ported it or a professional ported it? if you took too much material from the wrong places you may inadvertantly cause reductions in the velocity of the air moving through the runners.
ninety15.0
1,336
  • Nov 8, 2007
Were the heads installed as is...with no work done to them. Valve job? Milling?
The combustion chamber on those gt-40 irons is 64.5 cc i believe...which will drop your compression to under 8.5:1. So without any work done to them i would probably say the heads were only worth 20-25 hp and the intake work is probably worth another 10-20...depending on how well you did the port work. total increase of 30-40.
Those Gt-40's really need a lot of exhaust flow to be efficient...think longtubes, O/R X pipe, and some bullets or SLP's.
rsw007
469
Lexington,SC
Nov 9, 2007
  • Nov 9, 2007
thats possible about the velocity but the nitrous will make up for that i hope
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
