If someone can steer me straight I'd really appreciate it. I'm systematically attempting to build a decent car. Started with a 2.3 LX. I wanted to stay 4 lug, because I love the 10 hole wheels. I found GT front spindles and sway bar, and bought new struts, drilled rotors, 73mm calipers, Bendix pads, master cylinder, and front tires. I put it all on, had the car aligned, and was loving life. 10 miles later the left front wheel starts smoking and the burning smell was strong. I jacked it up, and the wheel would not spin with 1 hand pressure. Pulled the wheel off, unbolted and removed the caliper, and the rotor turned freely. The rotor was scored a little and the new pads seemed a little injured, definitely smelly. I decided I had received a dud caliper, so I picked up a new one and put it on. I noticed one of the prongs on the inboard pad had broken off, but they seemed like they had still seated okay. Bled the brakes and off I went again. Yup. life is good, that bigger sway bar is awesome, and the brake pedal pressure seems okay. I had worried cause I heard a stock master may have trouble pushing enough fluid for 73mm calipers. 10 miles later, I'm back in the driveway with the same symptom. Is it possible the new master cylinder is not releasing the pressure on the caliper after I take my foot off the brake? Or could it be the inboard pad with the broken prong? I appreciate any feedback I can get....I'd really appreciate your time and expertise. I'm ready to head to jump off the roof.
Ken in Pa.
Ken in Pa.
