GT40 intake and heads questions...
KingDiamond
637
Chicago, IL
I'm going to put in a KB 1500 supercharger sometime before next winter but I want to upgrade the heads and intake. There is a KB 1500 made for the GT-40 lower so I'm thinking about going with a GT40 intake and GT40P heads. I am budget minded so that's why I want the GT40P heads.
Can I use the GT40 lower with the stock upper? I will be removing the upper when I will have the KB supercharger so I don't want to spend $500 on a full GT40 intake when I can buy the lower on ebay for $150.
Also will the heads and intake just bolt on or will other things have to be changed like pushrods?
I will probably change the injectors to better ones when I do the head swap. Will 30 lb injectors be good for the KB 1500 @ 6 to 8 psi?
Also is the Pro-M a good MAF to get with the injectors?
I'm gonna have to dissagree. You CAN use your current headers or just normal headers for the GT40P heads BUT you're going to need to make something to be able to get the spark plugs out. A cut socket will work great. They do work it just might be a PITA :D
