Trying to decide which ones will make more power, the other parts will be a 10.1 compression stock stroke short block, an anderson n-41 camshaft, 1.6 pro magnum roller rockers, 70mm tb, 76mm maf, 24lb injectors, 155lph fuel pump, and a k&n filter in the stock box.
Judging by the parts listed which heads would you recomend, they will be getting a mild port and polish work before installation also.
What intake would you recomend to go with this also?
Thanks for your help and suggestions.
