gt40p combo
  • Thread starter Thread starter MustangMulch
  • Start date Start date Feb 20, 2004
MustangMulch
303
Santa Clarita, CA
Feb 20, 2004
  • Feb 20, 2004
My plan is to add an SC-trim later on down the line, but first i was thinking of adding this:
GT40p's
TFS street heat intake
TFS stage 1 cam
accufab TB (65mm or 70mm.. not sure)
and of course at some point i'll add 30# injectors and a AFPR. Should I do that with the h/c/i, or will it be ok to run the stock injectors until i get the blower?
How much power can I expect with just these things, and the mods in my sig? How about after the blower?
Also, with that combo, will I be able to add a blower pulley and run maybe 8-10 lbs of boost? Or what would I need to do to run more boost without hurting the engine? "Supposedly" my engine is bored .030 over to a 306, according to the guy I bought my car from a year ago. But i don't know how true that is. So let's just assume I have a stock 302. It has 47k miles on it right now.
MustangMulch
303
Santa Clarita, CA
Feb 21, 2004
  • Feb 21, 2004
can anyone take a stab at it?
9
90stangLX302
76
Good ol' Bellaire Ohio
Feb 21, 2004
  • Feb 21, 2004
"Also, with that combo, will I be able to add a blower pulley and run maybe 8-10 lbs of boost? Or what would I need to do to run more boost without hurting the engine? "
With the GT40p's and their 59cc combustion chamber, I would recommend not running more than 5-6lbs. The compression ratio will be to high causing deadly pre-detonation to your motor. Either go with a head with larger combustion chambers(gt40's) or go with a lower compression piston.
MustangMulch
303
Santa Clarita, CA
Feb 22, 2004
  • Feb 22, 2004
Any more opinions?
9
90stangLX302
76
Feb 22, 2004
  • Feb 22, 2004
You will also need "P" specific headers for the GT-40P heads, which you probabaly already knew.
I am guessing you will probably get about 50 hp out of those 4 mods. Someone correct me if i am off.
I am also doing the P heads with a GT-40 intake so any more opinions would be appreciated
MustangPunk302
1,051
West Michigan
Feb 22, 2004
  • Feb 22, 2004
59cc should get you close to 9.5:1 (w/ stock pistons). Cut 0.030" off the bottom and you're close to 10:1 (w/ stock pistons). Either way he'll be fine running 8-10 lbs, back the timing down to stock 10 degrees of cousre.
MustangMulch
303
Santa Clarita, CA
Feb 22, 2004
  • Feb 22, 2004
Yeah i was aware that the P's need special headers, but what about other heads? My original plan was to get some Twisted Wedges. Can you use any longtube or shorty header on those?
NeQX
904
Infront Of You, NY
Feb 22, 2004
  • Feb 22, 2004
I recommend Twisted Wedge heads and BBK long tubes and offroad x pipe and dynomax exhaust
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Gt40p headers
  • Mike3
  • Oct 14, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
Blackhawkxx
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
