GT40p Head Comparison
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Hi Folks!
Seems like there has been so much interest in OEM combos these days :)
I got to looking for something typical (Cobra) to put up next to one of the
best set of curves (Typhoon) I've seen from an oem iron headed
combo :D
Notice the peak hp values are really close
but
Peak hp values just do not tell ... the WHOLE story :Word:
Notice each end of the curve looks quite different :shock:
Notice the shorty headers are softer on the low end
Notice the Cobra starts to fall at only 5400
Now ... It is a rule of thumb ......
A mid length runner upper will give up a bit of low end :notnice:
yet
You see a pretty impressive low end on the Typhoon combo :nice:
and
Its all the more impressive IMHO
Since we are dealing with oem iron heads :eek:
Here is the deal on how that was done ;)
The LT's were used to offset the shorter runners :banana:
Last thing I wanna point out about the Typhoon combo
NO Tune was used :(
so
His low end could be even MORE optimized :eek: :shock:
I would like to add just one more thing
since
We got so many noobs lately :)
Can you see how the Typhoon uses more of the ends of his curve :D
This is what is meant by extending his power curve ;)
This is a perfect visual kinda thing to show how a steep set of
gears works so well with a combo such as this
and
If we had the Typhoon combo next to a little stocker Stang here ....
You would see very plainly why a steep set of gears does not work the
same with a stocker and h/c/i combo
anyway ... I'm done ramblin now :rlaugh:
Grady
Since we don't know how the Cobra dyno pull was calibrated there would be
no way to tell for certain :shrug:
It very well could have been done with a STD cal as a lot of them you see
these days are done that way :)
I have always preferred SAE over STD as it was used most of the time when
I started to do all my research several years ago.
I know STD produces higher results over SAE
but
I have not been able to find any kind of ruling or method to convert
STD to SAE
So ... how much higher ... I don't know but it would seem to be somewhere
around the range of 2 to 5% from what I can tell.
While the Cobra tq curve shows higher values in the 3500 to 5300 range
don't discount what is happening at the ends of the curves.
Grady
