GT40P heads on 289... What rockers used?
nittanylion45
OK, a bit of a strange question... I'm building a low buck 289 engine. I got a great deal on GT40P heads... They are complete with valves and springs.
Can I use the stock 289 rocker arms on these heads? With the stock bolts? Or will I have to buy either stock Explorer rockers or a stud conversion kit?
I'm trying to save some $
Any advice is appreciated
Jim.
[email protected]
Ony rockers that fit a GT40P head are the stock pedestal types. "Cobra" or Crane Energizer roller rockers (1.7 ratio) are a nice addition to these heads. 289 rockers won't work unless you have the heads drilled and tapped for screw in studs and guide plates.
krash kendall said:
I believe you will also need a set of headers for the GT40P heads due to the placement of a sensor port requiring a header flange bolt to be relocated.
You might need headers due to the revised angle of the sparkplug. I used a set of Tri-y with my P's, had to re-route #5&6 primary tubes for sparkplug clearence. But the bolted up just fine
Thanks!
Headgrinder... Thanks. I'd definitely take them for shipping cost. Let me know if you find them!
I have the headers already. I got a pretty good deal on the jet hot coated MAC shorties on Ebay. I think the fellow is still selling them on there... see:
Item number: 160053405875
Regards, Jim.
[email protected]
