GT40P's and Cobra-spec engine
jwzg
237
Prattville, AL
Is anyone on here running a Cobra spec engine (24lb injectors, Cobra EEC) with P heads? If so, what are your impressions or hard numbers. I have the stock H.O. cam, but I understand the Cobra cam helps produce more torque. I'm strongly considering a custom grind next summer, but since I'm trying to maintain emissions and factory driveablity, it makes sense to check out the alternatives first.
I don't think there is a single cam you could put on there that would cause you to have emmission issues that can not be resolved by simply adjusting air/fuel ratios like you normaly should when making alterations to your vehicle.
