How much RWHP does anyonr think this setup would make?
GT40 ALUMINUM HEADS 59cc PORTED & POLISHED
GT40 UPPER & LOWER INTAKE W/1" HEAT SPACER
24 lb. injectors
adjustable fuel pressure regulator
COBRA 1.7RR
E303 CAM
STOCK BOTTOM
70MM THROTTLE BODY
C & L 73MM MASS AIR METER
K&N/ COLD AIR INDUCTION
UNDERDRIVE PULLEYS WITH SMOG DELETE
CLUTCH FAN DELETE
MDS 6AL
TIMING @ 15 DEGREES
MAC 1 5/8 LONG TUBE HEADERS
O/R X-PIPE
40 SERIES FLOW MASTERS
3.73 GEARS
NATURALLY ASPIRATED HP?
150HP SHOT OF NITROUS?
Thanks in advance to all that reply.
24 lb. injectors
COBRA 1.7RR
E303 CAM
STOCK BOTTOM
70MM THROTTLE BODY
CLUTCH FAN DELETE
MDS 6AL
TIMING @ 15 DEGREES
O/R X-PIPE
3.73 GEARS
