Guys running short belt how do you...
ricgt88
255
Quebec, Canada
How do you prevent the power steering pump for squirting the juice like a mofo when you run a short belt ?
Almost got killed last year because I ruined a guy's t-shirt at the track cuz the power steering was squirting like a **** star ....
What exactly do you mean? That sort of doesnt make any sense. Running a shorter belt has nothing to do with how fast the pump is operating, it's the pully itself that turns everything. Your accessories arent speeding up just because you have a shorter belt.
ricgt88 said:
When the engine is running, the power steering reservoir squirts through the small hole on the cap even though it is not connected ?
How can this happen ?
Because your not using the proper cap that has baffles to prevent that from happening...
:confused:
I have the original cap ? Do you mean I need another cap ?
The original cap has some sort of rubber baffle under it...
Can someone explain me how can it be squirting ? It is not even driven by the belt ?
:confused:
Dude just go to your local auto parts store, in the HELP section
that is the section with a bunch of odds & ends in red packeging
you will find a new cap there for bout 5 bucks and yes it has the
baffles. so go get it :spot:
