this is going to be a little long sorry! anyway i am going to pick a place here in nj, that can do all of this work for me step by step. i want tyhe same shop to work on my car all the time if possable. i was thinking of this set up.
kenny bell blower, do they have different models? what will fit my needs?
fox lake p&p heads, stage one or two. which do you think?
and i will have my engine built, or buy a built one from dss or somthing.
o k i know that is what i want, but im not sure of all the steps i have to take, and was hoping that some of you could give me anything you know on these part, install, shops......
the order im doing things is heads first that built engine then blower.
when i build the engine, im not trying to make it faster just stronger. to deal with boost. however i believe that dss can build faster engines also, but i dont know if they can be boosted. whats the deal?
i need to be able to pass emissions in the end, thats whats making this so hard. compression, timing, boost, tune will all play a roll. id hate to do it all then find out i cant pass emissions.... can this be done and pass that is my goal.
also with the built engine, can i take of the revlimiter, and go higher into the rpm range to make more power without hurting anything?
you take and advice.....thanks
i know i am not going with cams that will be to much trouble to pass, i think i have enough on my plate.
