guys, what is the purpose of the dogbone?
ADRENLN
2,342
NJ
i know alot of people take this off, but what is the purpose? i would like to remove it, but not if i need it.
also i never had a car with a dogbone, can somone post a quick pick to make sure i remove the right thing. thanks :nice:
It's a harmonic dampner to deaden drivetrain vibrations. Some people get away with removing this 8lb weight, others start getting resonance at 65-75mph, which can sometimes be cured with an aluminum driveshaft.
It's the funky dog-bone shaped piece of metal bolted to the under side of the pumpkin.
To add to that....it's made to work with stock gearing only and once you perform a gear swap, it serves no real purpose (unless you want to count the additional few pounds it gives adds to the rear end for traction purposes). Otherwise, it's scrap metal
I didn't know that once you swapped gears it could be ditched..good info :nice: I may have to start forming a crush on you also :p if Tommy will share :rlaugh:
thanks everyone. i slithered under my car eairler today to take it off.
car was in the garage and i squeezed under didnt jack it or anything.
my car isnt droped yet so i can fit :D anyway i took the dog bone off with a socket wrench. not too much space the way i did it, but its no problem with a socket wrench.
the bolts are on a bit tight, but they came off. havent driven it yet, but if you guys say its cool, then its cool. :nice:
just make sure you re-attach the upper stamped steel brkt, as it serves as the contact point for the rear pinion snubber
