guys with door poppers and shaved doors in here
hey guys ok today i started to get a problem with my passenger door when i hit the butto to open the door i dont hear the popping soung all i hear is some sound to where the cables/connections for the door popper is at. and when I do it for the drivers side it pops open likes its suppost to. any ideas on what i could be? what should I check? could it be a fuse?
well where is the fuse, if a fuse was blown, than there wouldnt be any power to the pass door, and you wouldnt hear anything, it could be just a loose gnd or connection - open the door from inside and check all wiring-
Paul Perreca
The solenoid could be locked up. Like said above, since you have power it's not a fuse.
Pull the door panel and see if the solenoid is frozen, or if the connection to the latch is loose or broken.
Paul Perreca
well i checked the wiring and it all seems fine im gonna checkthe fuse tomorrow where exactly are they do you know? cuz i mean i dont hear anything on the door i hear a little sound down behind the stereo deck where the wires to the door. and thinking about hte other day i think a fuse did blow or something cuz after that day that door started acting up
Yes, definitely check the solenoid for a good connection and test it if you can remove it and give it 12 volts on a test bench.
You are probably hearing a relay clicking behind your stereo.
yea i checked today and it seem that the latch is loose or broken is there a easy fix for this? or will i have to take it to someone and get it fixed?
