it doesnt tho if put it in 5th and step on the gas it will just basicly bog and take for ever to get going.
Michael Yount said:Black93 and pairof9's - what rear gear are you guys running?
Black 93 Fox said:it doesnt tho if put it in 5th and step on the gas it will just basicly bog and take for ever to get going.![]()
Black 93 Fox said:Cory I never had 2:73'w always had 3:73's since I got the car.
lagging is bothering you now...saleenster said:tire size and tranny gears are probably the difference in your SN car.
2001droptizzy said:im sorry ..thats the gearing with my fox.
saleenster said:BTW..I use 5th gear as much as possible to help with gas mileage..however, in 4th gear @109 mph with a 26" tire I'm in the Red...probably top speed is somewhere in the mid to upper 130's not 150 like most think...
maverick0716 said:Do you still have the stock tach? Because if you have 3.73 gears, with a 26" tire you should only be turning 5235 rpm in 4th gear at 109 mph......and with 4.10 gears you would be turning 5754 rpm in 4th.
saleenster said:Good pt..yes I am running the stock tach. One thing to note, speed is calculated with very little to zero wind resistance...this can be another factor for higher RPM's at a lower speed.
saleenster said:I shift into 4th around the 90 mph area..but then have to shift into 5th @ 109 mph...if yours is not close to either of those, then either your speedo is off maybe from not calibrating to the correct one, or you dont have 3.73 gears..or you have a larger tire
gungfusemaj said:I had a 85 gt svt and I put 3.73 pos. and had t5 ...4th at 4500 doing 90 and then barking it in to 5th and max out 125 stock except the manifold and carb. and you know what it moved for a 4barrel
Come on now, do you think we're that clueless? That's kind of insulting. Chirping 5th gear?.....with a 85 "SVT" (no such thing) GT with only an aftermarket intake manifold and carb?
