Could someone explain the difference between adjusting tune settings with a handheld (e.g. SCT), using the tune they send you by mail on the SCT, and having a car actually dyno tuned. I understand on the dyno that they will monitor A/F and adjust accordingly to keep it safe, but what is actually adjusted....and is the same parameters adjustable by the handheld only, or do you need the actual Pro Racer pack to make the same adjustments? With the tunes that are sent with the SCT from wherever you buy it, can you make the same adjustments yourself using the SCT? Finally...if you get a tuner with included mail-order tunes, and say...add gears so you use the SCT to make those changes, will the mail-order tune still be the same and it just adds that change, or does it reset things?
Just trying to understand some of the differences. Thanks!
