Hard start when warm? Smoke?
  • Thread starter Thread starter NewBlueGT
  • Start date Start date Apr 7, 2005
N
NewBlueGT
1,409
San Luis Obispo
Apr 7, 2005
  • Apr 7, 2005
My stang is still suffering from hard start issues after doing some basic tune up work. So far I've replace all plugs/wires/cap and rotor as well as replaced a vacuum hose which goes from the side of the Cobra intake into a black box in the front passenger side (?). I thought that was the culprit due to a serious chunk of hose missing caused by my headers, but the problem is still serious.
First start of the day is normal, car runs well, if I then park from an hour or more and restart the car it barely turns over. 5-6 seconds of ignition and help from the gas pedel will start it, but it aint pretty. After the startup I get a large searching Idle, which stabilizes, a puff of white smoke, and the smell of gas.
Car still drives fine once its on.
Can someone check the top of that black box I mentioned, as of right now I have one hole pugged with a black cap, and the other is open. I'm wondering if I pulled on the vacuum hose to the point where it unplugged near there??
Thanks for the help guys
ss93cobra
1,422
Wilmington NC
Apr 7, 2005
  • Apr 7, 2005
Both should be capped. The "box" in question is actually the charcoal canister used for emissions purposes. Recirculates the fuel tank vapors into the engine for optimum emissions compliance. Regarding it being the culprit, I'd suspect either your fuel regulator or fuel pump given the hard start issue when hot aside from the fuel smell. Run a fuel pressure check for proper pressure as well as leak down.
N
NewBlueGT
1,409
San Luis Obispo
Apr 7, 2005
  • Apr 7, 2005
What does the cap look like that covers the second hope on top of the box?
Is it just a cap which plugs it, or is it a part??
What would be the effects of a car running without that cap in place, could that be the reason for these hard starts???????
ss93cobra
1,422
Wilmington NC
Apr 8, 2005
  • Apr 8, 2005
Both caps are the same in appearance and function. I've seen cars run fine with no caps at all actually. Worst case it may be a small vacuum leak, but I doubt it has anything what-so-ever to do with your concern. I'd start off with the fuel system as mentioned earlier.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
