  • 1994 - 1995 Specific Tech
Hard Starting and idle problems
  • Thread starter Thread starter Bloodgts
  • Start date Start date Jun 5, 2011
Bloodgts
  • Jun 5, 2011
So here the deal just got my 5.0 out of storage and put back together. The list of fixing and modding was pretty long, but to say the less the timing was nowhere close to correct. Now that its all back together it has a hard time starting and when it does start it idles at 3500+ (usally shut it down before it gets to where it stops). When I put it back together I lined everything up for TDC.
List of changes
TF Street Heat upper and lower plus adapter
BBK 75 TB
FR Water pump
New Timing Chain
New HB Pulley
New Timing Cover
MSD Dizzy
CAI custom built
Other than that somewhat stock
Thanks is advance
toyman
1,944
54
79
Vernon BC
Jun 5, 2011
  • Jun 5, 2011
Have you tried to pull codes? Pretty much a crap shoot without some diagnostic input other than hard to start and high idle and not knowing what was touched and/or altered.
HISSIN50
34
129
Jun 6, 2011
  • Jun 6, 2011
I would also be sure the throttle is not stuck (either the blade or the cable) and look for a large unconnected vacuum hose.
Bloodgts
  • Jun 6, 2011
Did some playing last night. Need to reset the throttle body, but it doesn't seem to be catching. Would try to pull codes, but the engine revs so fast that I have to kill it before it gets to hard to controll. Also put a jump pack on the battery and took care of the hard start and now I am just dealing with the high idle. When I get a chance I am going to check the vacuum lines.
HISSIN50
34
129
Jun 6, 2011
  • Jun 6, 2011
You can still pull EO and M codes with the car off (key on).
toyman
1,944
54
79
Vernon BC
Jun 6, 2011
  • Jun 6, 2011
Not certain what you mean by "reset throttle body". Did you mean reset idle? For it to be idling that high would indicate the throttle is open or the TPS sensor is sending a signal that corresponds to an open throttle. With the engine off, test the signal voltage from the TPS sensor. It should be about 1v. I would do this before anything else.
Bloodgts
  • Jun 7, 2011
What I meant by reset was backing everything off and putting it back in stock place, which did point out the promblem. I feel like a dumb S*** on this one, but the cruise cable was holding the plate just a little open take off cable and idles normal now
Thanks for the help
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
