Hardware for stock radiator over flow tank
PurdueSD
Anyone have any insight into what to use for radiator overflow hardware. Mine is all missing... Looks like it may have been some type of threaded clips with matching fastners.??
I was just changing mine over to a Canton tank today... there's 2 bolts with nut-clips that mount the tank to the fan shroud. Stock, they are 6mmx1.0 thread pitch, I think 20mm long. The bolts use a large washer so as not to pull through the plastic of the tank.
ACE Hardware will have some matching nut-clips and bolts, standard or metric doesn't matter, just get the clips big enough to reach from the square hole (which holds the nut-clip from rotating) to the round bolt hole.
