Have cobra intake, what about injectors?
I receltly purchased a cobra intake and was wondering if i would need to upgrade my injectors and mas air meter because i wasnt sure if it would run alright with the 19's. Also is there a big decrease in gas mileage with the 24lb injectors. Thanks for the help guys
24's will cause the car to run rich, which would likely effect mileage. The stock meter is calibrated for 19's you would need to replace it. You could get an adjustable fp regulator but I think the 24's would still be too much.
up to 300 horse or even more on 19 pounders.
also, I wouldn't go larger than a 65 mm throttle body unless you're running with alum heads and a good cam.
