Haven't been on in awhile...
98CLLGFND
Because Ive been busy with a PI swap. Its done and the car was running great. However, I hit a piece of 2x4 on the road test and it poked a hole in my radiator. One question I have is is there any after market radiators I can put in to the fix my problem. I was hearing that a stock 03-04 Cobra radiator will fit perfect. Is this true? Also, I grounded my alternator and it burned up the white fusible link that goes into the fuse box. How do I fix that?
I know wheres its grounding. The giant arc, smoke and flames made it really easy to find. Because I grounded it, the wire running into the terminal that then runs intot he battery burned up. It burned up where the wire connects into that terminal on the fuse box. Actually, right before that terminal, maybe and inch from it...
