HCI issues after completion
fordfx584
Tampa,florida
Hey guys we just finished up my heads cam intake swap.I chose to go with the trick flow package with the track heat intake,twisted wedge heads,and stage one cam.After completion i have some issues.First, i put in a kirban FPR and it came with a marshall fuel pressure guage.Well the guage does nbot seem to be working correctley and is bouncing every where.So there fore we were not able to set the fuel pressure.Im guessing this is why the car back fires every know and then,could that be why?We pulled the number 5 plug and it is really black.So i know the car is running a bit rich.My second issue is every7 seconds roughly the car makes a hick up noise(sort of like hitting the motor with a rubber mallet.It makes the car shake for a half second.It does not do it that often just like every 7 seconds.It almost sounds like the motor is hitting something?What can it be?The car has great oil pressure,and is staying really cool.The cam has a healthey nasty ass lope to it.Im just to the point know of taking it to the speed shop and saying fix it!!!!Im just really frustrated.I put a new balancer on today thinking that my stop the thud noise,but no it didnt.Well guys help me out!!!!!!!Ow and timing is set at 10 degrees for the spray.
Brandon
Are you 100% sure the plugs are in the right spot. Make sure the cam firing order is right as well. That is the problem with changing so much at the same time, it's hard to pinpoint. I would definatly take care of the fuel pressure problems first. It does do this with the vacuum line off, correct? Try swapping back out for the Kirban. Fix what's obvious, (fuel pressure) then check the basics, and if that doesn't work, then your going to have to dig deeper.
The knocking that you are hearing...does it happen only when the motor surges or does it happen all the time. Are you sure you didn't leave something in the motor or let something fall on a piston when you were not looking. As far as the fuel pressure goes i would put the kirban back on and go from there. It was on the motor before right?
Hey guys im positive all the plugs are on right.It runs fine at idle,its just when you give it some gas it pops and back fires occasionally.As for leaving something in one of the cyclinder walls,i highlt doubt it.I was very careful when it came to that stuff.And for the rockers being adjusted i had a buddy of mine do it ,and hes done it a few times before.I cant even hear the rockers so i guess thats a good sign?The noise is like someone hitting the bottom of the motor with a rubber mallett.It doesnt feel like the thud is coming from inside the motor at all?You can feel it when your sitting inside the car and when looking under the hood. Any other advise or suggestions would be gr4eat.I think what i may end up doing since i will have to do it anyways is just taking the car to get tuned.
Well no,The bolt on the actual header flange got stripped so i have to get a new one put on.So right know i have a hell of an exausts leak.So could this be the reason why i hear the Thud noise every 5 to 10 seconds?
