Head Question, Take a look
If need the cylinder heads worked on, make sure you get an experienced porter to work on the bowl area. The combustion chamber design is pretty important. :)
Isn't the bowl same as the chamber? or it's just a nickname ain't it anyways?
K so the heads I might be buying are 61cc, 2 of them are 62cc, and one is 65cc, it had detonation problems and I assume was ported out to clean up whatever damage. I'm thinking about getting a cc'ing kit and working the bowls till all the rest are 65cc and be done, any problems with this? and yeah I have done port work and cc'ing work, I just don't own the equipment.
My mistake. I was using the "bowl" (hence the general shape of the combustion chamber), interchangeably.
Sort of like...
1. More throttle response
2. Touchier throtte
