head setup.....
  • Thread starter Thread starter s2t8n9g
  • Start date Start date Apr 27, 2005
s2t8n9g
11
  • Apr 27, 2005
i was just wondering if the 351 w heads are a direct bolt up to the 5.0 block. I am considering doing this because i dont have the money for a set of nice heads and i happen to have a set of windsor heads and a block sitting around.any help is appreciated.
83 Capri 5.0
92
Vancouver, Canada
May 6, 2006
  • May 6, 2006
I would like to know as well. I searched these forums for this topic but only found this thread.
Head bolt size differences?
Will the stock EFI intake match up?
Will the coolant galleries match up as well?
Any other issues?
Already know about the stock flow deficiencies on these but they are done up with larger valves.
Also considering a mild cam, thinking about a B303. The stock block is an '89, anything wrong with using this cam? Any better ideas? Just doing a cheap mild bolt-on build, FYI.
Thanks!
RMODEL65
313
brunswick ga
May 6, 2006
  • May 6, 2006
gotta to be 69-70 351w heads will have a casting # thats c9 or d0 u will need to have some bushings for the headbolts! try and to find a set of 5.0 explorer heads they are direct bolt on dont even need the bushings and they out flow the 351 heads
83 Capri 5.0
92
Vancouver, Canada
May 6, 2006
  • May 6, 2006
I thought it was up to 74 can be used?
I know the Explorer thing, got em in my car, the questions I asked are for a friend who already has Windors heads ready to go.
So bushings for the head bolt holes, good.
What about the ports etc..?
Thanks again!
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
