Head Swap! 289->351w
Jake69
Paradise, CA
1969 coupe 302 shortblock w/ 289 heads, .280 intake .295 exhaust cam
I plan on changing my heads from stock(?) 289 to ported and polished 351w heads. I have a stock 302 shortblock. I have new head gaskets ready to go, along with the heads themselves, but as far as rocker arms and pushrods I'm not sure if they're interchangeable, and even if they are, are they're worth using to save a little cash? If I buy new rocker arms, should I go to a higher ratio? Any feedback is appreciated.
Hi,
In my view, unless you are getting a very good deal (read as "almost free") on the heads, I would go with Windsor JR, if sticking with iron heads. Years ago, 351 heads with their smallish valves (1.78/1.54), were pretty much our only choice. Today, we have so many more affordable heads. The JR's with their 1.94/160 valves, is so much better "untouched" than the 351 head. If add a little bowl blending and shave to arrive at a 10.0 CR, you've got a 'killer" street head.
As far as the 1.7 rocker ratio, you should always check the P/V clearance and the push rod geometry. Sure you'll gain a tiny bit, but unless you do all of the other stuff, you're wasting your money.
Good Luck!
Back when this was the trick setup, Ford offered pop-up pistons to keep the compression ratio up, otherwise it'll be lousy. Such pistons are still available, and not too expensive. I'd avoid shaving the heads to do this, if you cut them enough to matter, you'll have alignment problems with the intake.
The 70s called and they want their crappy heads back.
Not to be mean, but I do agree with the others. Possibly if a pro did the port work and he's a friend that will sell them to you for $200 it might be worth it. Otherwise the odds are GT-40s are better - you should be able to get them for about $200 if they are in great condition, less with high miles.
Best way to go is aluminum if you have the cash. Heads are the one thing to spend money on if you want a good performing engine. You still have to make sure all the components match up properly, but heads are really the key.
Where's Paradise, Ca? I didn't think CA had any Paradise anymore. I'm in Anaheim Hills.
Anyhow, what is your comp ratio now? You will loose about 3/4 of a point of compression unless the 351w heads have been decked some. Measure the chambers and see what they are. They should be in the 61cc area unless they have been shaved. What year are the 289 heads? Later 289 heads had larger chambers so you may not loose a lot of compression.
Andy Granatelli?...interesting. You can see from my sig info that there is nothing wrong with a set of well preped 351w heads.
Hey Chr.....
Where have you been lurking these days?
:nice:
